wall heat boundary
Old   August 27, 2004, 07:43
Default wall heat boundary
Marco
*** ERROR #320 *** INCORRECT WALL HEAT BOUNDARY SPEC AT PHYSICAL BOUNDARY
Anybody has encountered this error before and/or knows what it means exactly?
By doing "Check everything" in the Star GUI, I don't get any warning or errors. Only when I start the calculation I get the message reported above. Any help is welcome!
Thanks, Marco
Old   August 27, 2004, 08:13
Default Re: wall heat boundary
Richard
It means something like you have a solid-fluid interface whose walls do not have the conduction condition for heat. Basically, check the thermal boundary conditions on all your solid-fluid interfaces.
Old   August 27, 2004, 10:32
Marco
thanks for the reply.
All fluid-solid interfaces have the conduction heat condition on: what else should I check?
Old   August 30, 2004, 04:16
Richard
Maybe check that your solid-fluid interfaces really are solid-fluid interfaces: perhaps there are cracks there so that the solid is not attached to the fluid. Also check the exterior walls are not specified as conducting.
Old   August 31, 2004, 07:28
steve
You can see the offending boundary by turning on the "echo boundary and body information" switch in prostar and then look at the info file for the problem cell/boundary.
Old   September 9, 2004, 09:50
jing
have you turn on the conjugate heat transfer button?
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 12:20
energy source at boundary VS wall heat flux CFX New CFX 2 June 28, 2007 03:00
Wall boundary condition (heat transfer) Arnold FLUENT 4 February 16, 2006 22:35
*** ERROR #320 *** INCORRECT WALL HEAT BOUNDARY... bv Siemens 2 September 12, 2005 03:09
Heat Transfer & Boundary Conditions across 2D wall SAAD Main CFD Forum 6 March 13, 2005 12:42
