Solution divergence
Old   August 25, 2004, 00:33
Default Solution divergence
Julie
I'm running the case with liquid fuel injection, evaporation and combustion. I tried MARS and UD schemes, under-relaxation coefficients of 0.1, but it doesn't help. The solution still diverges and the file fort.101 is been written. Do you know what a file is that? How can I converge my solution?
Note, that it worked well before I turned the turbulent dispersion model on. Now it is turned off, but the solution still doesn't converge. It seems like the progrdm "remembers" the previous settings, though I've deleted all the auxiliary files, except the model file.
Please help!
Regards, Julie
Old   August 30, 2004, 05:21
Default Re: Solution divergence
Michiel
Check all your setting again. I sometimes found that prostar doesn't set all your settings. Save your file read it again and see if everything is set alright.
solution divergence due to turbulence Haider FLUENT 1 October 18, 2006 07:27
Divergence Docker FLUENT 7 April 17, 2005 19:02
converged solution or correct solution SAM FLUENT 1 October 12, 2004 15:38
turbulent viscosity causes solution divergence Steve FLUENT 0 December 23, 2002 11:36
Divergence detected in solution Kevan Moodley Main CFD Forum 7 June 28, 1999 08:12
