August 31, 2004, 06:29 |
Droplets injection goes crazy!
I'm modeling liquid fuel evaporation and combustion. With UD the calculation runs and converges ok, but when I choose MARS for momentum and density calculation - it diverges after 325th iteration (before it converged after 1700somethingth iteration). The drops go completely crazy, filling all the volume of the vaporizer (before there was just one nice track line) and going in the opposite ditection they should, i.e. towards the injection point. Can somebody explain this? PS I work on v3.150A. Regards, Julie |
August 31, 2004, 07:07 |
Re: Droplets injection goes crazy!
I'd say don't worry too much about the droplet tracks. They are just following the velocity field. You need to worry about why the velocity field is diverging. Have you tried reducing the under-relaxation factors for velocity and pressure? Quite often these need to be lower with MARS than with UD, say 0.5 and 0.15 respectively.
August 31, 2004, 08:58 |
Hi Richard,
Yes, I've tried to lower the under-relaxation factors, but not so much (min to 0.4). Now I runned the case with UD for density and MARS for momentum and it seems to work well (at least it converged)even with under-relaxation factors of 0.6 for momentum. Regards, Julie |
[Netgen] Compiling Netgen on Fedora Core is driving me crazy | jango | OpenFOAM Meshing & Mesh Conversion | 3 | November 9, 2007 13:29 |
Crazy element ids-1! | Bela | CFX | 0 | April 10, 2006 03:47 |
crazy gradients | Luca | FLUENT | 0 | March 22, 2006 12:49 |
droplets injection | Sébastien ERNANDES | Siemens | 1 | July 9, 2004 02:41 |
Droplets injection | Julie Polyakh | Siemens | 0 | May 10, 2004 02:29 |
