-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   solid- solid interface (http://www.cfd-online.com/Forums/cd-adapco/54011-solid-solid-interface.html)
Peter September 1, 2004 05:48
Hi everybody,
I am trying to calculate a thermal problem with convective heat transfer and conduction between two solids. Do I have to define a boundary condition between the solids- as wall-conductive for example? What is assumed if I don't define a boundary between the interface solid-solid? The solution doesn't converge for the enth of the solids?
Thanks
jing September 9, 2004 09:46
Re: solid- solid interface
for such a case, if you use the conjugate heat transfer approach, you don't need to define a boundary on the solid-solid interface. Otherweise, yes.
