Home > Forums > CD-adapco
negative volume
Old   September 10, 2004, 21:50
Default negative volume
wak
Hi..
Anyone ever facing this ..
*** WARNING #090 *** VALUE ELOG*YPLUS OR LOG*EFFVIS/(CAPPA*VISCOS) IS LESS THAN 1.1 AT 149 CELLS.UPLUS=YPLUS LAW IS USED. IF THIS SITUATION PERSISTS, INCORRECT RESULTS MAY BE OBTAINED.
After several iteration my calculation stopped, because star detect a negative volume. My case is transient sliding mesh.
Thanks in advance..
Old   September 12, 2004, 07:54
Default Re: negative volume
Richard
The warning #090 is telling you that your mesh is too fine for the high Re turbulence model which you are using. This is just a question of modelling accuracy. You can choose whether to ignore it, change the mesh or change the turbulence model.
The negative volume is something else: this is telling you that your mesh motion is wrong and is corrupting the mesh. Check your mesh motion commands. You could do a mesh preview run: this will highlight the problem faster than you doing a full analysis.
Thread Tools
Trackbacks are On
Negative volume Mahbub CD-adapco 7 April 28, 2011 08:04
Negative Volume in CFX Barbara CFX 2 January 10, 2008 11:19
negative volume Avesta FLUENT 2 June 19, 2004 06:34
Negative Volume sen CD-adapco 2 January 19, 2001 00:43
negative volume Sabatini CD-adapco 4 October 26, 2000 10:07
