How to correct the errors and warnings??
Old   September 14, 2004, 14:21
Default How to correct the errors and warnings??
Arnab
I started again and made the model for tutorial 11.1 with star-cd V3.2 but I have some errors due to which i am having warnings while writing geometry file.
The errors and warnings are:
*error-74 there are cracks in the model
*error-265 model has groups of disconnected cells
Begining geometry write to file tut11 geom
** warning- no cell found for boundary 375 in region 5
** warning- no cell found for boundary 378 in region 5
Boundary set cleared
** warning- 2 boundaries not found on any cell in the model
guys, help me out.. can anyone tell me how to overcome these errors??
Thanks in advance,
AB
Old   September 28, 2004, 06:55
Default Re: How to correct the errors and warnings??
Hubert
error-74: - check the grid in the NavCenter - let it generate a new cset from the error cells (cracks) - first merge (using vmerg) the vertices - find out if there are double cells overlapping.
error-265: - that belongs to the previous error
there are some boundary faces for region 5 defined of cells which are already deleted. remove all the boundary of that inlet or outlet and generate new one.
I hope that helps
Hubert
WARNINGS I don't want to have Gabriel Siemens 3 August 10, 2007 18:04
Not to display warnings? Yasser Nabavi FLUENT 3 June 4, 2006 09:27
WARNINGS DB Siemens 0 January 19, 2006 14:47
Warnings Dave Siemens 2 November 9, 2005 22:08
lots of warnings Arnab Siemens 2 January 27, 2005 16:36
