PMOVLINK for windows
Dear All,
How to run pmovlink script on windows 2000. Iam using STAR-3.15. Thanks in advance Bhaskar |
Re: PMOVLINK for windows
In the "Solve" dialog box, check the moving mesh box. If using the command line, use "pmov."
I think it is pmovrun not pmovlink.
Dear Bhaskar,
Currently I am running pmovlink script on Windows XP from the command prompt (DOS) by typing pmov and then enter your case name. I am thinking that it will be the same procedure considering that you use Windows 2000 systems. But, please make sure that your working directory is under your transient case. Please try it and good luck. wendy |
