Species Source in COMET
Old   October 20, 2004, 20:13
Default Species Source in COMET
Derek Coon
I would like to make a species source at a Wall boundary in COMET. I am trying to use spesou.f, but getting nowhere. Can someone write a brief example where the faces of region 1 generate 0.001 kg/sec of species 1 please? Thanks in advance.
Old   October 22, 2004, 09:10
Default Re: Species Source in COMET
4xF
EITHER you use spesou.f and in that case you have to set the source term in the cell next to the wall, since spesou.f is called for the fluid domain (in which case you need to switch on the flag -- see the SPECIE command -- to be able to use this subroutine)
OR you use the subroutine userbc.f (in which case you need to set the user subroutine flag on -- see the BDEF command in Cometpp) to set boundary values
Old   October 22, 2004, 11:35
Derek Coon
Thank you for your help. I figureed out last night that spesou.f would only specify for cells. Do I use the LK(K) variable to figure out the cell indices?
I would prefer using the wall boundaries themselves as the source, how do I do this using userbc.f? (Which variable?)
Thanks again.
Old   October 24, 2004, 07:05
4xF
I think you meant LB(K) for getting the cell next to the wall, where K is the boundary index. For imposing the value at the wall within userbc.f, give the value into cb(ibofs(is)+K) where is is the species index (for the rest, look at the file ListOfVariables in the userprog directory).
UDF: species source term Luc FLUENT 3 July 30, 2019 07:38
Species source DH FLUENT 1 April 19, 2017 13:16
species source in star ccm+ jef Siemens 3 April 11, 2008 14:46
source of species with UDF, please!!!!!!!!! Jason FLUENT 7 November 12, 2007 12:57
Species Source Term Johannes FLUENT 3 March 30, 2007 17:46
