Parm.inc error when running analysis
Old   October 30, 2004, 07:13
Default Parm.inc error when running analysis
Chris Wood
Hi Guys
Wondering if you can help me. Im trying to run a 2D model at the moment, once the meshing is complete I try to set analysis options before writing .geom and.prob files then an error occurs saying no parm.inc file could be found? Does anyone know how I cen write a parm.inc file or where I can find it..
Thanks
Chris
Old   October 30, 2004, 07:40
Default Re: Parm.inc error when running analysis
Kevin
Hello Chris,
I think if you go ahead and just write the *.geom file it should create the parm.inc. Also you might get errors in writting the geometry due to bad cells so I would make sure I have a perfect mesh before finalizing the problem file and setting up boundary conditions.
Kevin
Old   October 30, 2004, 07:47
Chris Wood
Ok Kevin
Thanks for your help, will look at it now and try evaluate the problem regions...
Chris
Old   November 1, 2004, 12:28
Samir
A Param.inc error can be due to several reasons. I used to get a similar error when the license file for StarCD cud not be read!!!
setting NCTMXD=NCMAX in parm.inc Lokesh Siemens 0 March 5, 2009 13:27
Floating point Error while running MRF analysis Kashif FLUENT 1 November 21, 2007 01:15
FIDAP RUNNING ERROR "ERROR-DIR-NOT-EMPTY=145" BAOYU FLUENT 0 January 26, 2006 18:32
setting NCTMXD=NCMAX in parm.inc ROr Siemens 2 November 4, 2005 09:40
Running new analysis Julie Polyakh Siemens 1 October 21, 2002 08:16
