Proam ERROR:Could not allocate more memory
Old   November 8, 2004, 10:17
Default Proam ERROR:Could not allocate more memory
Erika
When I try to run Tetfix to fix cpmatches or unresolved cells for mesh with almost 800000 trimmed cells, it often happens that it doesn't work and the BAMM Online Help appears with the following error:
**ERROR - COULD NOT ALLOCATE MORE MEMORY
**ERROR - COULD NOT ALLOCATE MEMORY TO INCREASE PARAMETER MAXSC2 TO 413009760 MAXSC2 IS CURRENTLY 43696879
I'm using a PC with 1G of RAM, but I don't think the reason is the RAM dimension beacuse I monitored the RAM status during the TetFix Run and it doesn't use the whole memory (almost 40 %).
Does anyone knows which could be the reason for this error and how can I fix it?
Thank you!
Old   November 8, 2004, 13:21
Default Re: Proam ERROR:Could not allocate more memory
Brian
It is most certainly the RAM - you don't have enough for that operation.
Old   November 8, 2004, 19:10
Jihwan
Old   November 8, 2004, 19:14
Jihwan
I had the same experience. Even if you have enough memory for generating trimmed cells, STAR use much more memory for TetFix operation. I increased the RAM from 3G to 6G and finaly got no error message. Good luck Erika
Old   November 9, 2004, 06:17
Erika
I cannot increase the memory up to 3 or 6 G!!! How many cells did you have when you needed a 6G RAM?
Thank you anyway!
Old   November 9, 2004, 19:32
Jihwan
To my memory, I had 1.5 M trimmed cells when I cope with the problem. Anyway, you would need 64 bit CPU machine in order to fully take advantage of larger memory than 4G.
Old   November 9, 2004, 21:17
Kevin
Erika,
Sometimes it is helpful to close the model and prosize again. The MAXSC2 can be very difficult I have problems when using the ezip command.
For some reason I thought your custom mesh had cpmatch errors because you said during the generation of the trimmed mesh. Now I get it, you have unresolved cells and cpmatch erros after the trimming process.
When you did the trim, did you have the AFT and GROW TET FIX activiated also cell-division should be activiated? These are found in the advanced options.
I would probably fix by hand between 20 - 30 unresolved cells, for the cpmatches if you are O.K. with partial boundaries, then leave them, Did you run the following cpcheck.
cpcheck,,all,,,news,,fix
Kevin
Old   November 10, 2004, 03:41
Default Re: Proam: Memory allocation and cpmatches errors
Erika
Ok, For MAXSC2 I will try to run prosize again.
For cpmatches errors, sure, I find it after the trimming! I usually have the ATF and GROW TETFIX activated and the CELL DIVISION not disabled (then activated) as default.
I tried to modify this option:
-disabling ATF and TETFIX I found more unresolved cells and sometime (but only sometimes) less cpmatches errors
-disabling CELL DIVISION I found concave cells
Yesterday I try to use your command cpcheck,,all,,,news,,fix but one cpmatches error remain and the programm stalled, then it has a segmentation fault and it closed itself. When I opened it again I found the database locked.
Don't worry, It was not the first time that it happens this "database locking": anyway, do you know how to fix this problem? I saw that the file .dbs is not empty as it seems, but I cannot unlock it!
For cpmatches errors I'm trying to use the TetFix procedure.
Thank you!
Old   November 10, 2004, 21:07
Kevin
Erika,
I usually delete the files associated with *.lck*, I believe there should be two. When these are deleted the "dbase list" command will show all your databases.
I am suprised that is crashed during the cpcheck command.
By the way what is the geometry you are trying to mesh?
Kevin
Old   November 16, 2004, 12:10
Erika
Hi Kevin,
I'm trying to process a pump ciruit from an inlet to an outlet, full of simply water with no slip walls. Unfortunatley I have problem also with the solution convergence in Comet!
Last week I obtained a good mesh with a boundary layer and no poorly formed cells (I fixed the cpmatches errors and Poorly Formed Cells by running TetFix), but I can't get the convergence in Comet!
I tryed several things by changing under relaxation factors, using pseudostationary model, trying different boundary conditions,... the mass residue decreases at the beginning, but diverges at the end!
Probably the geometry is too complicated, but it's the real one and I need to use it!
Do you use Comet to do CFD analysis? Any suggest?
Thank you!
Old   November 16, 2004, 20:42
  #11
Kevin
Dear Erika,
I am impressed that you got a trimmed mesh into Comet without problems. I use Comet, but mainly for VOF, free surface flows. If you only want the solution for water than I suggest going back to star because it is more robust for simple flows. If you want free surface or caviatation, stick with Comet.
I suppose you already knocked down the under relaxation factor for pressure to be 0.02.
If it is a moving mesh, I can not help, but if you are looking for the stationary flow in a pump I can help, Is there a way for me to download the *.mdl file? Send me an e-mail.
Kevin
Cannot allocate memory for arrays (1400,1000) Quarkz Main CFD Forum 5 January 27, 2008 06:38
Failed to allocate memory. Tufsen FLUENT 0 February 26, 2007 10:28
Gambit unable to allocate dynamic memory Abhijeet Karnik FLUENT 0 October 2, 2006 12:59
Can not allocate memory~ lenson Siemens 2 March 23, 2005 20:44
INSUFFICIENT SPACE ON MACHINE TO ALLOCATE MEMORY Andrea CFX 2 October 19, 2004 13:10
