Warning 519 - Initfi activated but not used
Old   November 9, 2004, 20:45
Default Warning 519 - Initfi activated but not used
AB
I am getting this warning message and the simulation is done with all 0 values and so no result and no output.
How to get rid of this warning and how to run the simulation so that I see some meaningful results and numbers.
Old   November 9, 2004, 21:40
Default Re: Warning 519 - Initfi activated but not used
Kevin
My guess would be that you have activiated a user subroutine in the problem file and you are not using it. Is it your attention to use user subroutines? If not than remove "user" from what looks like the initialization window.
Kevin
Old   November 10, 2004, 09:53
AB
i want to use the user-subroutine. but the model was written in version 3.15 and i want to run it in 3.2 but i see that the model is not using user subroutine.
How can I make the user subroutine to work?
AB
Old   November 10, 2004, 10:03
ted
The subroutine is already activated, which is why STAR says "Activated but not used".
This means that bcdefi is activated, but STAR is not using your coding. This is either because it isn't there, or because it is there but it doesn't compile.
Check that: 1. the bcdefi.f is in the ufile directory. 2. read the screen output to see if bcdefi has compiled correctly. If bcdefi is in the ufile directory, then chances are it hasn't compiled correctly. If this is the case then STAR gives you the fortran error message.
CAPTCHA extension activated Jonas Larsson CFD-Wiki 0 June 15, 2007 18:20
Warning#42 43 44 furkan Siemens 1 December 18, 2005 17:23
