-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   moving-grid don't work in linux. (http://www.cfd-online.com/Forums/cd-adapco/54181-moving-grid-dont-work-linux.html)
Dorain November 17, 2004 21:56
Linking pmov executable...
FORTRAN 77 Compiler 7.5, Copyright (c) 1987-2001, Absoft Corp. /opt/absoft/lib/libfio.a(ioerr.o): In function `_ioerr': ioerr.o(.text+0x1fb): `sys_errlist' is deprecated; use `strerror' or `strerror_r' instead Linking single precision sequential executable "star"...
FORTRAN 77 Compiler 7.5, Copyright (c) 1987-2001, Absoft Corp. /opt/starcd/solve/libstar.a(newgrc.o): In function `pstrt_': newgrc.o(.text+0x10e): `sys_errlist' is deprecated; use `strerror' or `strerror_r' instead newgrc.o(.text+0x105): `sys_nerr' is deprecated; use `strerror' or `strerror_r' instead
F.K. November 18, 2004 07:51
Re: moving-grid don't work in linux.
use the following fortran levels:
star 3.15 fortran 7.5 patched twice!!!! star 3.22 fortran 8.2
ted November 18, 2004 10:15
Are you sure this is actually an error? The reason for this message is that there is a discrepancy in the absoft version that you are compiling with, and the version that was used to compile STAR. My experience of this message is that it is a warning only, your executable should still be compiled and will still run.
4xF November 18, 2004 14:29
I agree with Ted. The error message is just a warning that you are using old objects (hence the "deprecated"). The executable will still run on your computer.
