Mesh overlap.
Old   November 18, 2004, 10:33
Default Mesh overlap.
Samir
Hi; I am simulating in a bend, i need to use different mesh patterns. 1) i try to create a cylindrical toroid, then in the center i create another rectangular toroid, in 3-D. How do i get rid of the cylindrical mesh in the region of the rectangular one. The Star mesh n geometry check shows no errors, but i can see two meshes on top of each other instead of a merged. (i also tried to use the merge command) 2) i tried to extrude it by creating a 2-D square in a circle. It does not let me select more than 8 points for creating a block. Now i cannot mesh it without creating a block?....I need some hints on both of the above. Thanks in advance.
how to control overlap in partitioning smilor CFX 7 February 12, 2009 16:25
Why Non-overlap interface occur in 1 to 1 mesh? kake CFX 8 December 14, 2006 00:24
Mesh overlap problem Samir Siemens 4 November 19, 2004 04:08
overlap cells CAgner Main CFD Forum 1 April 15, 2004 08:29
Mesh overlap/internal wall CAH FLUENT 1 December 5, 2000 00:56
