Compiling Error in prostar
Old   November 18, 2004, 11:58
Default Compiling Error in prostar
Erika
I'm trying to use prostar to do a simulation. It's the first time with prostar and I don't have so much time so I run proam, I generated a trimmed mesh and then I followed Star-GUIDE to fill the other infos. At the end, I tryed to run the solver, but I got this message:
close,volume2_3_f.drp FILE volume2_3_f.drp CANNOT BE CLOSED OR NOT OPEN
PRO *>
Message passing library: Sequential
Linking double precision sequential executable "star-volume2_3_f.exe"...
f77: unrecognized option `-N3' f77: unrecognized option `-N26' f77: unrecognized option `-N15' f771: Unrecognized option `-f' ######################################
WARNING: Command execution error. Please check screen output for details
starin.f compile error.
Exiting starlink.
Does anybody know which is the reason? I'm working in Linux with a GNU fortran compiler.
Is it a problem related to my model or to the compiler (for example I have to set some particular variable or ?) ?
Thank you in advance,
Erika
Old   November 18, 2004, 12:13
Default Re: Compiling Error in prostar
Samir
try using only prostar pre and post and simulate for less number of iter jus to see if it works.
Old   November 18, 2004, 12:16
Erika
It does't begin to simulate! It cannot compile!
Old   November 18, 2004, 12:19
Samir
I think that should be a problem not with Star CD but with the installation i guess. What OS r u runnin.
Old   November 18, 2004, 12:24
Erika
I'm using Linux; I don't know any more information...and net administrators are already gone away...I'll let you know tomorrow...thank you anyway...
Erika
Old   November 18, 2004, 13:07
Pauli
GNU Fortran is not supported under Linux. You must use Absoft. It's all explained in the installation notes.
Old   November 18, 2004, 13:50
kevin
You need to use Absoft Fortran to compile
Old   November 22, 2004, 04:13
Mallikarjun
You have to install the correct version of Absoft. STARCD V3.22 supports Absoftv8.2.
Compiling error quansp OpenFOAM Installation 1 April 20, 2009 07:37
Errors when Compiling UDF: error C2040/error C2099 Julian K. FLUENT 1 December 21, 2008 00:23
UDF error in compiling Shin FLUENT 1 December 15, 2007 20:25
UDF COMPILING ERROR Sandilya Garimella FLUENT 4 November 1, 2007 11:21
prostar Error Pialisen Siemens 2 September 9, 2006 14:06
