Cracks
Old   November 22, 2004, 11:37
Default Cracks
dave
Dear all,
I have inherited a few grids that I need to solve, and I've got cracks in the grids and am having trouble correcting.
Often I've created two new shell cell types, and assigned the offending cells to be one of the new shell types. Then selected them and used the line: cshell,shell type, cset to make a master and slave set.
Then used : cpcreate, shell, master shells, slave shells.
This has generally worked, but not in this case.
Has anyone, got any other useful/good techniques for getting rid of cracks in their models.
Thanks in advance for any assistance, Dave
Old   November 22, 2004, 21:09
Default Re: Cracks
Kevin
Dear Dave,
When I have two large surfaces that I need to cpmatch, I also create two different shell types and use the cpar command. (Sorry I can not give the full command but I do not want to give you something wrong)
If your cracks are random, I would first try merging out any vertices.
cset news fluid
vset news cset
vmerge vset,,.001
vmerge vset,,.01 (The number depends on your cell size, make it much smaller than your smallest cell)
You can also try this,-------------------------------
cset news fluid
live surf create
scheck,cset,,mani,news
ctab 99 shell 6
cmod cset (Now you know where the cracks are)
grow (vset news cset;cset add vset any)
grow
cset subs fluid
cpset news cset any
cset add cpset
cpmatch cset
Sometimes the command cpmatch cset creates couples that are not wanted, so be sure to
cpcheck,,all,,,news,,fix
you can put in a tolerance, for example lets say you are O.K. with 15% uncovered,
cpcheck,,all,,,news,.15,fix
Old   November 23, 2004, 04:20
Default Re: Cracks
dave
Kevin, thanks very much for your suggestions. I'll give them a go.
Cheers, Dave
Cracks in Mesh SN Siemens 2 July 26, 2006 05:30
cracks in ES-ICE mesh escapist Siemens 2 July 10, 2005 05:53
How to delete cracks Raghavendra Siemens 3 May 24, 2005 01:15
Cracks Franch Siemens 1 February 14, 2002 08:53
How to fix cracks in a tet mesh Ron Siemens 1 August 14, 2000 20:07
