Problem with export data from prostar
Old   November 27, 2004, 22:55
Default Problem with export data from prostar
Shanta
I am a mechanical engineer and I am working with star cd. but I am a beginner.
My problem is -how to export data from prostar to other such as techplot and after what condition?
Thank you all. Pls help.
Old   November 27, 2004, 23:48
Default Re: Problem with export data from prostar
AB
Under the Nav Center, you have option for exporting data to various packages in various forms and it is very simple to use.
Or In the command window, u can save cdsave and click enter to save the input, boundary, cell and vertex file which you can easily import to other packages.
send more message if u are unsuccessful and be specifc so that I can try to help u in a better way.
AB
problem about export data Rui Siemens 2 January 18, 2007 22:16
data export Holo FLUENT 5 May 4, 2006 04:24
block generation problem by PROSTAR Mehdi Siemens 0 April 26, 2006 05:34
2-d problem BOUNDARIES IN prostar stk Siemens 1 March 19, 2004 07:03
Problem: graphics display in prostar main window Jiaying Xu Siemens 8 February 14, 2002 08:08
