script for running star
Old   November 29, 2004, 14:49
Default script for running star
Celia
Hi all,
does anyone know if I can write a script file to run ./star so that I can run it with nohup. My broadband connection often closes down and this results in termination of the running job.
I have almost no idea about scripts, so if you can let me know how I can do this I would be very grateful.
Celia
Old   November 30, 2004, 04:10
Default Re: script for running star
4xF
Something like that should do:
#!/bin/sh WORKDIR=`pwd` ${WORKDIR} star.exe <<EOD star y EOD exit 0
Have fun...
Old   November 30, 2004, 08:23
Jamie
batch scripts can be automaticaly created.
With v3150A, starlink with options (to see options, "starlink -h"):
starlink -snfc casename -e star.exe
(s = single precision, n = no subroutines, f = overwrite existing executable of same name, c = casename, followed by actual casename, e = executable name)
This creates a file called star.batch. If using standard v3150A, you'll have to edit the file and change "timex" to "time" unless the timex command exists on your machine. To start the analysis
nohup ./star.batch &
standard output will automatically be sent to star.log.
If you're using v3.2, execute star with the -batch option, i.e.
star -batch (single precision. for double use star -dp -batch)
This creates a file called batch.sh. Simply starting this will *not* send standard output to a file. I start it like this:
nohup ./batch.sh >& star.log &
Then standard output goes to star.log.
Hope this helps.
Old   November 30, 2004, 19:12
Celia
Thanks guyes, I will give this a go
Old   December 1, 2004, 21:56
Celia
I tried both... does'nt work
4XF... I wrote a file with your commands, used touch +x filename to create an executable.. when try to run it complains..."bash ./filename: /bin/sh: bad interpreter: Premission denied
Jamie... it does'nt seem to creat any batch file using the command.. I am using v3150A...
Old   December 2, 2004, 03:27
Jörn Beilke
if you type "starlink -help" you see the options. assume that your casename is "case" (case.mdl) type
starlink -c case
and the file star.batch is created. If you are on a linux box you have to edit the file and remove the timex command.
Old   December 2, 2004, 03:29
Jörn Beilke
starlink -c case
The script should look like:
#!/bin/sh
./star > star.log 2>&1 <<EOD
case
EOD
Old   December 2, 2004, 09:16
Guillaume
If your aim is only to start a star run and close your connection you do not need any script. Simply type in the following order:
star > toto case ^Z bg
Usually a job is killed when the output window is destroyed by closing a connection. The first line flushes the output in a file and no more on the window (standard output).
The second line answer the star question ``case name" (but now this question is displayed in the file toto and not on the window).
The third line (ctrl Z) freezes the simulation in order to be able to switch to background (fourth line).
Wait few seconds and open the toto file, you should see the simulation continuing. You can log-off.
NB Do not try to directly type ``star > toto &" as you cannot enter the case.
Old   December 2, 2004, 22:46
Celia
Thanks guyes... its working
script file for running fluent on linux cluster Worth FLUENT 2 February 9, 2012 11:31
the problem of running star-cd after pro-star liu-jinsong Siemens 0 November 20, 2008 20:58
the problem of running star-cd liu-jinsong Siemens 1 November 4, 2008 04:52
Running script files without opening grafic inter Jim CFX 0 March 21, 2006 06:57
Script Files for Star-CD? Cary Siemens 3 May 21, 2001 04:36
