Home > Forums > CD-adapco
Extrude cells.
Old   November 29, 2004, 17:30
Default Extrude cells.
Samir
How do I extrude the single thickness 3-D cells in to a toroid.
Old   December 6, 2004, 10:28
Default Re: Extrude cells.
Chris House
I'm pretty sure to do this you have to create a 2-D baffle then use the command vcextrude. I don't think you can extude a 3D cell. This extrusion and toroid stuff is covered in the STAR commands book.
Old   December 7, 2004, 03:40
Samir
hey chris , Thanks for the reply. Thats what i am trying to do. Could you give me the simplest example using vcextrude for a cylinder, explaining what is what in short.
Old   December 7, 2004, 08:08
Volker
This is how I do it: 1 Add shells on the surface you want to extrude (you can use the cell tool for that) 2 Put shells in a set 3 Compress vertices (vcom all, you will get an output of your maximum vertex number) 4 Renumber vertices of your shells, so that they have the highest numbers of all vertices (vren disc xxx cset, where xxx is your first vertice number you want to use which has to be bigger than the maximum vertice number from the previous step). 5 Use vcextrude command (have a look in Help-->Commands for the options). Once you know your way through this, it can be a very useful command....But if you don't do the vren and the vertice offset in vcex right, you can damage your mesh. Therefore, saving the mdl before is strongly advised.
Good luck
Old   December 7, 2004, 08:34
Jörn Beilke
http://www.adapco-online.com/adapco_...sh1/index.html
Thread Tools
Trackbacks are On
ICEM CFD 5.0 - 2D to 3D Mesh Extrude James Date CFX 7 October 22, 2013 03:46
[urgent] ICEM: from 2D to 3D using extrude Hao CFX 3 March 11, 2010 13:01
ICEMCFD - 2D - EXTRUDE Daniel FLUENT 3 August 9, 2008 22:13
extrude 2D mesh stefan CFX 1 June 8, 2008 21:41
How to extrude 2D Mesh in ICEM CFD? VSB CFX 7 December 27, 2006 12:58
