determine the density of heavy fluid in cavitation |
December 2, 2004, 04:58 |
Hello everyone!
When I calculate a case of cavitation,I should set the density of the heavy fluid in subroutine.But when I try that,the density can not be changed. If I can reach my aim, and how can I do that? Can anyone help me!! Thanks a lot!! |
December 2, 2004, 06:55 |
Re: determine the density of heavy fluid in cavita
If you want to do a cavitation calculation you should use at least version v32. And there you can't specify the density using subroutines. It is completely defined within prostar.
Display Modes | |
density of fluid and mixtur | greg | FLUENT | 1 | May 26, 2007 10:47 |
Which solver I should use when density of the fluid is not a constant | dbxmcf | OpenFOAM Running, Solving & CFD | 0 | March 25, 2007 05:26 |
how to define initial velocity of heavy fluid | hezheng | Siemens | 1 | May 31, 2004 00:02 |
Heavy Gas Dispersion | Roued | Main CFD Forum | 1 | December 17, 2001 04:10 |
PC or heavy machine for CFD? | X. Ye | Main CFD Forum | 13 | September 16, 1999 03:51 |
