December 3, 2004, 08:03 |
cluster on Linux
1) What is the upper limit on number of cells if I use 2 Xeon and 4 Pentium IV machines?
2) If I use 6 Xeon machines? 3) If I use 1 Itanium and 5 Xeon machines? |
December 3, 2004, 10:54 |
Re: cluster on Linux
The limit has little to do with the processor, but rather the amount of RAM available to each processor.
I typically use a rule of thumb of 1 million cells per megabyte of RAM. This is a conservative rule - you can often get away with more, but you run the risk of memory paging which slows things down to glacier speed. That means if you have four processors each with 1MB of RAM, you should be able to handle a 4 million cell case. But keep in mind that pre and post processing is done on a single processor, so the practical limit to a 32 bit machine, which can't address more than 3.5 - 4MB of RAM (depending on architecture), is about 4 million cells. |
December 3, 2004, 12:03 |
The other problems are building the model or writing the geometry file. Using a 32 bit machine you can only build a model of 3 to 4 million cells no matter how much memory you have. To build a larger model you need to go to a 64 bit machine.
If you try writing the geometry file of a model in excess of 4 million cells using a 32 bit machine you get at least one error for every cell you have. It takes awhile for >4 million errors to scroll by. Tom |
Display Modes | |
how to use -ssh w/ Fluent on Linux cluster | Bill | FLUENT | 4 | April 2, 2014 01:04 |
HPC on a Linux cluster | Jihwan | Siemens | 2 | November 22, 2005 11:17 |
LINUX CLUSTER | co2 | FLUENT | 1 | April 24, 2004 05:30 |
linux cluster | Johan Carlsson | Siemens | 6 | July 4, 2003 13:02 |
linux cluster | Johan Carlsson | Main CFD Forum | 2 | June 21, 2003 08:14 |
