temperature below the initial condition
Old   December 15, 2004, 08:15
Default temperature below the initial condition
Anna (aka new-user)
DEar Experts,
Here is a general problem: I am solving a natural convection case and my teperature drops below the initial value. There is no cooling, no air inlets, so the question is where does it come from??? it happens locally near the walls and in the cormers of the model.
I use the low Re no. k-eps model of turbulence.
Thank you
a.
Old   December 15, 2004, 10:55
Default Re: temperature below the initial condition
Pauli
Check your wall boundary conditions (including the default region 0).
It sounds like one or more walls have a temperature below your intialization temperature.
Old   December 15, 2004, 23:48
Brian
Also check that the problem is real and not simply interpolation related.
Do you still see these low temperatures when you look at cell data (GETC) rather than vertex data (GETV)?
Old   December 16, 2004, 04:41
Anna (aka new-user)
The boundary values are ok, and getc shows this low temperature. It always happens near the wall especially in the corners of the mesh (but there are no warnings in the info file). Also if you inspect the minimum temperature in the info file you can see that it is 10 K lower than it should be...
but... magic! I've opened the different version of the mdl file (the same settings, just it's been stored in different directory and not touched during all the restarts) and it produces correct results! fantastic! am so relieved! (<- irony)
those files seem to be the same, they have the same size and so on, but one of them happened to be just slightly corrupted...
cheers
a.
patching-initial temperature Lousa FLUENT 2 September 14, 2007 11:36
Initial Temperature Luise FLUENT 0 September 12, 2007 10:31
initial temperature in unsteady state Cristian FLUENT 8 August 4, 2007 01:37
initial condition Silke Renner FLUENT 1 July 28, 2005 13:12
Initial Condition Y. Shen Siemens 1 December 20, 2000 04:34
