Home > Forums > CD-adapco
Un-connected surfaces and ProAM cutting
Old   December 17, 2004, 17:31
Default Un-connected surfaces and ProAM cutting
Gudrun
Does anybody know how to create a trimmed mesh in ProAM without bothering about full node-to-node connectivity for the surface mesh?
Old   December 19, 2004, 14:45
Default Re: Un-connected surfaces and ProAM cutting
steve
You need to look into the surface wrapper as a quick way of creating a fully connected surface mesh.
Old   December 20, 2004, 13:16
Pauli
I am pretty sure ProAM requires a closed surface (water tight, node-to-node connected, etc.).
One route to investigate is surface wrapping. Another (albeit more tedious) is application of the hfil & ezip commands.
Old   December 20, 2004, 14:05
Jörn Beilke
It should be possible to use a not closed surface with the switch "disable surface check" but the result might be not perfect.
This is the same as the "new surface" option. But there you just use the new created surface and not the volume mesh.
Old   December 20, 2004, 17:18
Gudrun
I agree with you Jörn, theoretically it should be possible, and it has shown to work in practice as well. i would however be happier if the poor mesher could create a sub-surface from a un-closed surface. This absolutely seems not to work.
Thread Tools
Trackbacks are On
can the modeFRONTIER be connected with CCM+? Mclaren CD-adapco 8 July 10, 2016 15:23
Mesh: Surfaces not connected Babs FLUENT 8 September 17, 2007 05:29
Help needed... connect surfaces (connected in CAD) Cyril FLUENT 0 September 11, 2007 13:53
connected and connected bientity in gambit scott FLUENT 2 October 18, 2006 16:51
cutting laser Giovanni FLUENT 0 November 27, 2001 12:14
