Home > Forums > CD-adapco
Recirculation problems
Old   December 30, 2004, 17:05
Default Recirculation problems
Simon
I am simulating a simple diffusion flame. I am using a 2D square mesh. One side of the square is the two inlets (fuel stream in the center, the rest is the oxidizer stream) and the opoosite side is the outlet. The velocities of the streams are O(cm/s). The problem is that I don't get a converged solution, because I keep getting inflows at the outlet boundary, along with recilculation regions. Could the boundary conditions be faulty? Any suggestions are more than welcome.
Old   December 31, 2004, 02:35
Default Re: Recirculation problems
Brian
0cm/s? Zero? That would be a problem indeed. Perhaps a typo?
However, it is entirely likely you would get recirculations with such a setup - and the associated inflows on the outlet. Try extending the length of the mesh or contstrain the outlet to a smaller area.
Old   December 31, 2004, 13:59
Simon
Yes, a typo indeed. I meant that the velocities are order of cm/s. The problem is that I tried extending the mesh length-wise, but the recirculations persist. If the required increase is more than, say, three times the given length, then there has to be some other way.I was wondering whether I could impose some sort of velocity profile at the outlet (steep hyperbolic, perhaps) but STAR-CD doesn't allow something like that, as far as I know. Any ideas about which boundary is the proper one in such a case? Thank you in advance.
Old   January 1, 2005, 06:50
Brian
You most certainly can impose a velocity profile at the outlet, using boundary type inlet and a table or user coding to specify the velocities.
But it could be tricky balancing the mass flow closely enough.
I would suggest a test case where you make the outlet boundary smaller, like just a portion of the existing boundary. This may not be the case you want, but it would most likely allow a sufficient degree of convergence for you to see what is going on.
The other alternative is to use a pressure boundary at the outlet, but this has its own stability related issues.
Old   January 1, 2005, 07:40
Vladimir
Hi Simon
I noticed that extendsion of the domain did not help so what I would do is get rid of the type of BC at the outlet you used (I mean OUTLET). I would recommend you to switch the OUTLET to PRESSURE bc.
Hope it'll help.
Old   January 1, 2005, 19:58
Simon
Thank you everyone for the suggestions. I will try them out asap. And a happy new year to you all.
Thread Tools
Trackbacks are On
how to do recirculation problems in fluent arvind FLUENT 0 October 14, 2008 00:58
Recirculation Abdul CFX 3 June 25, 2007 03:35
Recirculation Simran Saini FLUENT 3 February 1, 2007 03:02
Recirculation Simran Saini FLUENT 1 January 18, 2007 23:51
recirculation ander Main CFD Forum 1 October 30, 2000 06:15
