How to confine scalar to positive values
Old   January 24, 2005, 21:53
Default How to confine scalar to positive values
Sheila
Hi everyone,
I am writing the k-w SST model in STAR as 2 scalars. I know that the model already exists in STAR but for my work I need to model them as separete quantities.
At the moment one of te problems I am having is that the minimum value of my k is always a very small negative value rather than zero. Any idea on what I can do to make sure the minimum is zero? Thanks in advance for your help. Sheila
Old   January 25, 2005, 13:57
Default Re: How to confine scalar to positive values
4xF
RCONS 64 2
Old   January 25, 2005, 15:04
Sheila
Thank you!
Old   January 27, 2005, 17:32
Default its not working...?!
Sheila
Hi 4xF,
its not wroking...
I am still getting a negative number as the minimum.
Sheila
Old   January 28, 2005, 03:15
Default Re: its not working...?!
matej
Unfortunatelly - I cannot tell you, where I got this info, whether it was adapco-online.com, or support, but still: the 64 switch works like this:
Setting rcon 64 to 1 clips the scalars between 0 and 1 for density calculation only, rcon 64 2 additionally clips the scalar values. (This seems to work only for active scalars.)
So it need not work for you. Can you limit the scalar with min-max in your user routine?
If it goes negative too much, It might be better to find the problem(source goes wild, or something)- where it originates and not to cure the effect ))
good luck
matej
Old   February 1, 2005, 14:06
Sheila
Thank you
Calculated Values in scalar field arkangel OpenFOAM Running, Solving & CFD 0 June 28, 2007 07:53
UDS for positive scalar Jun FLUENT 3 August 26, 2003 17:26
CO Scalar Values Ted Siemens 0 February 4, 2003 20:48
NEAGTIVE SCALAR VALUES Mario Siemens 1 November 18, 2002 02:01
How to enforce positive values Ning Main CFD Forum 10 August 20, 2000 00:10
