Home > Forums > CD-adapco
Porous Media with heat transfer
Old   January 10, 2005, 03:13
Default Porous Media with heat transfer
I want to simulate a porous media with heat transfer with StarCD. I am new user to this field, any help will be helpfull.
Also please guide, how to select the values of 'beta' and other coefficients.
Old   January 11, 2005, 07:42
Default Re: Porous Media with heat transfer
Well, there are many steps to go through. The porosity values you need to enter are of course material dependent, and usually come from measurements of pressure drop vs. velocity. As far as the heat exchange is concerned, you need to use so called hxinput.dat files, which are then used by the heat exchange subroutines of StarCD. They contain usually characteristic curves describing the amout of heat being exchanged for a certain value of coolant/air/whatever fluid is going through your material.
Old   February 23, 2005, 04:01
Hello, first thnak you for this rubrique , iwant to know if there is a good literature in the doamin modelisation the radiative heat transfer in porous media and how to find it .all the approximation and models.and eventually the software. thanks
Thread Tools
Trackbacks are On
Heat transfer within Porous Media Twiti CFX 6 November 7, 2015 10:29
REG POROUS MEDIA HEAT TRANSFER Rashmi Venkat FLUENT 6 June 1, 2006 05:13
Porous Media With Heat Transfer A.S. Main CFD Forum 1 January 10, 2005 04:56
Heat transfer in porous media Sri FLUENT 0 January 16, 2002 23:54
heat transfer in porous media Jörg Brozio FLUENT 1 March 28, 2000 23:17
