Home > Forums > CD-adapco
recirculations at inlet/outlet cavity
Old   January 17, 2005, 14:11
Default recirculations at inlet/outlet cavity
Abe
My question is about unsettled/unrealistic recirculations at the inlet and outlet cavities.
I am modeling a cavity between rotor and stator. In the entire cavity, there are some flow obstructions attached to stator like labyrinth teeth. I defined high/low static pressure at inlet and outlet boundaries. Rotor surface is rotating at an rpm. I like to calculate mass flow rate as function of pressure drop.
I used k-epsilon approach. I turned on "density ideal-f(T,P)" for compressible flow. I tried many options to have a nice streamlined flow at inlet/outlet cavities. It looks like rotor speed in the tangential direction causing the recirculation problem. I defined a linear tangential velocity which is maximum over rotor and zero at stator. I tried zero gradients on pressure boundaries. I extended/shortened the inlet/outlet cavities to get a developed flow conditions. However none of the tries have worked so far.
Any ideas to resolve the problem would be appreciated.
Thank you in advance for any help. Abe.
Thread Tools
Trackbacks are On
Could anybody help me about the specify inlet and outlet liugx212 OpenFOAM Running, Solving & CFD 4 February 13, 2006 11:53
how to set inlet and outlet? green Phoenics 5 May 18, 2004 23:52
one inlet and two outlet Fluenter FLUENT 2 March 28, 2004 23:23
use outlet as inlet Karin Phoenics 3 March 31, 2003 22:12
Outlet -> Inlet How? lego CFX 2 August 13, 2002 12:23
