How to divide the transient Solution file
Old   January 18, 2005, 05:26
Default How to divide the transient Solution file
Narmin B Hushmandi
Hello Everyone,
I am doing transient simulations and the number of my cells are about 400'000, always after 68 iterations the calculations are stopped and the error message is that the size of the file is exceeded, is there any possiblity to divide the transient solution file and save it in different files while running the analysis or is it possible to increase the allowable size of the transient solution file?
Thanks
Old   January 18, 2005, 09:03
Default Re: How to divide the transient Solution file
pavan
No matter how many cells you have in your model, the simulation must work.becos i am working with more than yours but my model is still working for 60000 iterations.It may be something wrong with your parameters.Please check it once again the total perameters.
Old   January 18, 2005, 09:49
Brian
How fast that file grows depends absolutely on what you choose to save in it and how often. Even a small mesh will give you a very big file very quickly if you save every variable every iteration.
In most cases, files are not allowed to get bigger than 2GB - I am pretty sure that you are hitting this limit. Reduce the number of variables saved, if possible, and most definitely the frequency, and you should be fine.
Old   January 19, 2005, 00:50
Anton Lyaskin
I can't figure out now the way you can automate it, but doing by hand you can run simulation for say 60 timesteps, rename your case.pstt file to case1.pstt, make a standart restart for another 60 timesteps, rename to case2.pstt and etc. For postprocessing you can load all those files specifying their names in the list (it's pretty straightforward when you come to this stage).
Old   January 19, 2005, 08:00
Jörn Beilke
it should be possible to use the posdat.f for this purpose. It might work like this:
if level eq 1
if ITER modulo number_of_steps == 0
system (mv .....)
You somehow have to dynamically create the name of the file to prevent overwriting.
PLOT3D ASCII solution file to MATLAB data file Sandeep Rana Main CFD Forum 4 June 11, 2010 09:48
Transient solution Amir Jourak CFX 0 July 9, 2007 16:27
TRANSIENT SOLUTION CONVERGE MARK Main CFD Forum 3 November 2, 2006 10:08
Transient Run solution diverges Narmin Siemens 1 February 15, 2005 05:31
Transient solution Elyyan FLUENT 2 December 2, 2003 03:26
