Home > Forums > CD-adapco
doubts
Old   January 20, 2005, 16:31
Default doubts
Xobile
1. how do u specify whether the simulation is compressible or incompressible in star-CD?? any option? or any function of density??
2.how can one see moving mesh problem as to whether it is running properly or not without worrying abt the thermophysical models. is there any special button? and how can one do the post processing so see diffeerent positions of a moving body wrt a stationary body.
Old   January 20, 2005, 20:14
Default Re: doubts
Jörn Beilke
Usually it helps very much to read the manual and work through the tutorials.
Q2) rcon,4,1
Old   January 21, 2005, 04:12
Default Re: doubts
Bart
In the STAR GUIDE Thermophysical Models and Properties\Liquids and Gasses\Molecular Properties
for Density Tab select Ideal-f(T,P) this make the density a function of temperature and pressure, which is incompressible flow. A constant density is used for incompressible flow. Check your Mach numbers to see if you actually need compressiblity (Ma<0.3 incompressible)
Old   January 21, 2005, 13:11
Default Re: doubts
Somnath
For moving mesh u read the tut-13 of star-cd and then try to see how it moves.Basically u have to execute some coding thru a loop facility of star-cd.
Thread Tools
Trackbacks are On
Doubts related to DPM...Thank you all for help Kushagra FLUENT 3 August 20, 2008 03:20
Some doubts about my mesh Jack CFX 3 July 10, 2007 12:16
Doubts Arnab Main CFD Forum 1 September 14, 2004 13:22
Need Some doubts to be cleared Arnab CD-adapco 3 March 29, 2004 17:35
some trivial doubts Arnab CD-adapco 2 March 25, 2004 06:57
