Home > Forums > CD-adapco
Detailed Description
Old   January 27, 2005, 16:38
Default Detailed Description
Arnab
My Warnings are :
*** WARNING #060 *** DENSITY OUT OF BOUND DUE TO PRESSURE CORRECTION AT CELL 509895 DENSITY= 1.2515E-03 LIMITER APPLIED GIVING UP AFTER PRINTING 50 #060 WARNINGS Total number of #060 warnings: 5820
AND
*** WARNING #057 *** EQUATION OF STATE IMBALANCE AT CELL 509774 IS 1.710664E+00 EQUATION OF STATE IMBALANCE FOUND AT MORE THAN 100 CELLS - PRINTOUT OF WARNING MESSAGE STOPPED
I want to give you more details of my simulation for you and others to better understand the problem and give me suggestions.
My CASE:
1.Transient, Moving mesh (Rotor moving at 10300 rpm and stators stationary).
2 stagnation inlets and 2 pressure outlets as it is a 4 port configuration.
3. Molecular properties: Ideal f (T,P) , Constant default properties for Air in terms of Molecular viscocity, Cp, Conductivity and Molecular weight.
4. Turbulence Model - K-epsilon High Re
Thermal Models - (conservation- static enthalpy, enthalpy- thermal)
Initialization - Default Initialization flow with 0 max vel and atmosphere pressure and temp.
5 Monitoring and Reference cells at outlet with atmospheric pressure assigned.
6. Max number of corrector stages : 50
Reduction in Residual for corrector stages = 0.25
under relaxation for pressure correction = 0.01
scalar solver - method - CG
Implicit Temporal Discretization
Solving for U, V,W, Pres, Turb KE, Turb Diss, T .
Differencing schemes - UD and MARS
7. Time step : 1.21 e -10 sec.
run for 0.005825 secs
Still I am getting these warnings at all time steps for almost all the cells i guess:
AND
Old   January 27, 2005, 16:57
Default Re: Detailed Description
Arnab
Also I am getting this error sometimes when I use static conditions for inlet instead of stagnation:
After 1st Iteration:
Calculation stopped due to negative densities in more than 100 cells..
Help me!!!
Arnab
Old   January 28, 2005, 07:15
Somnath
u can try by reducing the residual tolarances to avoid the negative density.
Thread Tools
Trackbacks are On
detailed chemistry EDC model Jimmy Andersen FLUENT 6 November 1, 2014 20:22
CFX: combustion with detailed chemistry JY CFX 2 November 24, 2005 03:25
Fluent: combustion with detailed chemistry JY FLUENT 2 October 13, 2005 15:15
Fluent: combustion with detailed chemistry JY FLUENT 0 October 12, 2005 18:09
