[Sponsors] | |||||
does anyone have any tutorial or simulation which uses pseudo transient approach as an initial guess for flow field initialization? I am running a high speed compressible flow and would really appreciate any help, |
A tutorial what for? Just switch it on, set your time step (in your case 1.E-08) and run it! There's nothing special that could be mentioned in a tutorial!!!
hope this helps Piet |
when i am running steady state option for high speed compressible flow... it is giving me a converged solution.
But when i run the same case for pseudo-transient case, the simulation stops due to negative densities in more than 100 cells.. of course my time step was 0.1 will decreasing my time step to 1E-8 solve this issue?? |
try reducing residual tolerance for primary variables to avoid this problem
Yes, your are absolutely right. It can solve your problem. Maybe 1.E-8 is not small enough! Try to lower it further for several hundred steps and enhance it from time to time. Any hint for such cases is to start the calculation with a dependency of temperature. This means rho = f(T) and switch back after lets say 100 iterations.
best regards Piet |
Rep Power: 3 ![]() |
What is the difference between pseudo transient simulation and transient simulation?
Sijal Ahmed Memon (turboenginner@gmail.com)
Rep Power: 30 ![]() ![]() |
Transient simulation is to solve the problem in time-accurate fashion, while pseudo transient is method to get the steady state solution
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| pseudo-transient | kathir | CD-adapco | 0 | November 30, 2006 05:56 |
| pseudo-transient | new-user | CD-adapco | 0 | October 8, 2004 03:59 |
| What's the advantage of Pseudo-compressiblity? | lololo | Main CFD Forum | 1 | June 12, 2002 08:44 |
| about pseudo time | Atit Koonsrisuk | Main CFD Forum | 1 | June 1, 2001 12:51 |
| Pseudo-Steady Simulations | Greg Perkins | FLUENT | 0 | October 11, 2000 23:35 |
