Home > Forums > CD-adapco
How to put quickly a velocity profile in a table?
Old   February 2, 2005, 07:17
Default How to put quickly a velocity profile in a table?
Stephane bone
I would like to put the velocity values of the output boundary in a table.
I have U, V, W in post register 1, 2 and 3 ; YCOR and ZCOR in post register 4 and 5 (I don't want XCOR because it is constant).
Then, I would like to create a table where I will have U, V and W following YCOR and ZCOR. I think I have to export registers in a file and to import it in a table but I don't how to do this.
Then I will use this table as inlet boundary condition.
Thanks for your help.
Old   February 3, 2005, 05:37
Default Re: How to put quickly a velocity profile in a tab
carno
use following commands to get these data in file.
ofil star.out
print cset (or all)
close star.out
print screen
you will find star.out text file in the working directory. Open this in MS excel to create a table.
Old   February 3, 2005, 09:09
Stephane bone
Thank you for this answer, this is a quick and good way to extract data.
Now, I would like to create a tbl file thanks to the table editor with these data.
Anton Lyaskin (another user of this forum) told me to write :
Table name Local 1 (cartesian coordinates) Voption extra independent Y 920 Z 0 Y Z U V W . . . . . . . . . . . . . . .
But I still have problem to open this file as a tbl file. I can do minor modification in the Unix system thanks to the text editor. However, if i need to do major modification, the only way I have is by using Excel or Word in a windows environment. Then, I don't know if the export text file is readeable by Unix.
Old   February 4, 2005, 04:44
carno
read help or tbread command. It is very well written there as said by Anton. I think any text file (like *.tbl) can be opened in any text editor irresptive of OS.
Hope this helps.
Old   March 2, 2005, 13:11
Toni Vainio
Hi, I have managed to create an excel sheet with the velocity values at all cells. This is really good. However, In Star Cd, how do I plot cells say from cell number 30 to cell number 50. Thanks
Old   March 8, 2005, 11:45
Stephane bone
I've got the answer to my problem thanks to Star-Cd support.
In fact, it seems that there is a problem with tbread in my workstation. I am using Unix in Sun.
If I try to read a tbl file I create following tbread, I obtain a fatal error with the following message "Segmentation fault - core dumped".
However, it is possible to read this tbl file as a boundary condition.
Thank you for your help.
Stephane
Thread Tools
Trackbacks are On
Velocity profile as an velocity intlet condition kees FLUENT 3 April 16, 2008 18:35
velocity profile as an velocity inlet condition KEES Main CFD Forum 0 April 15, 2008 11:26
Velocity Profile Moh FLUENT 5 November 28, 2004 06:56
3D velocity profile S. Sarkar FLUENT 3 July 28, 2003 18:12
particle velocity and velocity profile HGG FLUENT 2 June 10, 2001 16:32
