Home > Forums > CD-adapco
Compressible Fluid in COMET
Old   February 15, 2005, 19:58
Default Compressible Fluid in COMET
saang
I have tried to implement compressible fluid with free surface flow by defining "density in user subroutine" for specie 1. Actually, it likes there are 2 materials in one domain (Domain Mat is air (constant density)and Specie 1 is water (compressible density)).
But the solution is blown up. Does anyone face this problem before and how you guys tackle it?
By the way, i am doing fine to solve compressible fluid in the regular domain (one material in one domain)
Old   February 18, 2005, 07:57
Default Re: Compressible Fluid in COMET
JBS
If have the same problem with cavitation. The pressure denpendent density description for the liquid works fine as long as I do not activate cavitation. But when activating the cavitation I get NaN for the produced species in the first Iteration (although there is no cavitation at the beginning of the simulation at all).
I have a support case on that, I'll report when I have news on that.
Old   February 18, 2005, 18:50
saang
I didnt activate any cavitation. I just use "Free Surface with HIRC". I got the same result as yours that NaN error occur at SP1 at very first iteration of the first time step.
Please let me know if you have any further information. It would be great if you could email me directly. Thank you in advance.
Old   February 22, 2005, 11:19
4xF
You can't run compressible VOF using the COMET solver. This is inherent to the design of the solving algorithm itself when the free-surface modeling with HRIC is used. The formulation is based on the assumption that the fluids (liquid & gas) are inmiscible and the flow is incompressible (since div(V)=0 is assumed for the free-surface modeling).
Old   February 22, 2005, 12:47
JBS
I don't use HRIC for cavitating flows.
Old   February 22, 2005, 22:16
saang
To Mr 4xF,
Thank you so much for your help. It's very helpful informatin.
By the way, my model is about to squeeze the volume to gain the pressure (due to bulk modulus of water) and, then track the free surface.
Is it possible to implement compressible fluid at the first few time steps without "free surface", and then, in the later time step after I got the pressure, I turn "compressible fluid" off and turn on HIRC for free surface?
Old   March 5, 2005, 03:18
xhliu1
I have the same problem with JBS,If some one can help us to solve it!!
Old   March 5, 2005, 03:24
xhliu1
Hello,everyone! I want to change the solving algorithm in star-cd,is it possible?
Old   March 5, 2005, 22:36
xhliu1
I have a problem with cavitation. The pressure dependent density description for the liquid works fine as long as I do not activate cavitation. But when activating the cavitation I get NaN for the produced species in the first Iteration (although there is no cavitation at the beginning of the simulation at all).
As I using the cavitation model,density of the heavy fluid just can be set as a constant number.Can I using some method to solve this problem?
Old   March 19, 2005, 22:45
Tridib
Hallo everybody,
I have COMET software(education version). I need the full user manual. Please help me in getting a comet user manual.
Tridib
Thread Tools
Trackbacks are On
Two Phase Flow with compressible fluid benru OpenFOAM Running, Solving & CFD 0 November 2, 2007 02:09
re:compressible fluid flow satya FLUENT 4 November 30, 2006 00:30
tatal pressure in compressible fluid manoj korde FLUENT 0 June 4, 2006 03:44
COMET: fluid-solid interaction Mauro Malve CD-adapco 2 January 28, 2004 05:04
Compressible Fluid + Finite Volume mehdi Main CFD Forum 0 June 6, 2000 08:31
