Attach 2 Models
I am working with V3.22 on SuSe 9.1 linux. I want assembly 2 models so I write vertex, cells and couples from one model and I read them in the second, but when I read I obtain a strange mesh. Maybe is the Attach or couple problem What can I do to solve this problem? Could someone give me a hint? |
Re: Attach 2 Models
Make sure that you offset the vertex and cell numbers and couples when you read them in so that they don't overlap the original model.
Re: Attach 2 Models
hi may be your couple was not created properly.If couple was not created properly then you will get this kind of shapes...check it...
Re: Attach 2 Models
I donīt know How the offset vertex, cell and couples works, can you help me with this
Tanks |
Re: Attach 2 Models
How create de couples properly?
