-   Siemens (https://www.cfd-online.com/Forums/siemens/)
-   -   How to solve the problem for table and Les? (https://www.cfd-online.com/Forums/siemens/54407-how-solve-problem-table-les.html)
Ben Lu March 1, 2005 02:23
My model is the pipe form.There are two inlets and vertical each other,and one outlet.Time Domain is transient and turbulence model set is LES/smagorinsky.The curve of two inlet velocities are developed flow,and the values are used by tables in option of Define Boundary Region.Differencing scheme select "CD".After i start apply the "start new analysis",Startcd shows the error" error occurs in readying table.Form the proble file.its data is ingnored".And When th turbulence model is K-E/High reynolds and velocity used by table,Starcd didn't shows above error and could run to result.How to slove the error please? thanks
