March 1, 2005, 04:20 |
Help me~ERROR#266
My model is pipe form.There are two inlet and vertical each other,and one outlet.The values of two inlets are used by table. Time model is transient.Turbulence model is les/smagorinsky.After i star the Starcd,but Starcd shows the error "Error226 Error occurs in reading table
Form problem file,and its data are ingnored." And Prostar ourput shows the waring" temporal discretization is set to implicit . crank-nicholson is recommend for Les turbulence models." Although i change "implicit"to "crank-nicholson",but starcd shows the error "Error 404 analysis must be transient and cannot use upwinding for velocities to use an les turbulence model" Although i already set time model to transient and use by CD ,Starcd still shows the same message.Everybody,how to solve above all errors?help me~thanks |
strange fluent error: Primitive Error at Node 0 | Jean-Baptiste | FLUENT | 8 | June 14, 2022 11:11 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
"Error: Floating point error: invalid number" | MI Kim | FLUENT | 2 | January 4, 2007 10:00 |
Fatal error error writing to tmp No space left on device | maka | OpenFOAM Installation | 2 | April 3, 2006 08:48 |
Error: Floating point error: invalid number | Bob | FLUENT | 3 | June 3, 2005 18:11 |
