Home > Forums > CD-adapco
force on one rotor blade
Old   March 4, 2005, 10:07
Default force on one rotor blade
Narmin
I am simulating an axial air turbine, the geometry was such that I had to make the grid for the whole circumference. It means that I am simulating the whole turbine. I am doing transient analysis and I want to get one rotor blade force on different time steps. The method that I have used is such that I have specified the wall boundary around the perimeter of one blade and in the monitor boundary options, I have selected forces item to get the force components on the blade, I have specified a rotational speed as the speed of rotors to the wall boundary. When I want to get the value of the force components for the specified blade by using the Edload or Edgraph commands, all of the values are zero. Is the method that I am using, wrong? Are there other methods in the code to get the force on one rotor blade?
Second question, I want ot make the entropy contours, is it possible to do it in Star-CD? An alternative way can be to make the contours by the entropy function, is it possible to specify a function and get the values of that function for different cells and make the contours?
Thread Tools
Trackbacks are On
Help ( rotor blade design in wind turbine) shan FLUENT 3 June 3, 2009 03:57
Help setting up Fluent for a rotor blade Fluent learner FLUENT 3 July 11, 2006 12:01
calculating blade force nabeel FLUENT 0 September 16, 2004 05:31
rotor blade simulation Cesare Ghermandi CFX 0 July 29, 2004 05:30
helicopter rotor blade simulation Cesare Ghermandi CFX 1 June 8, 2004 19:27
