Pressure plot problem
Old   March 10, 2005, 21:32
Default Pressure plot problem
vatsa
hi all i did a simple flow analysis of exhaust piping system with inlet (uniform velocity) and outlet(flow split = 1) BCs. with turbulence - k-e model
instead of getting more or less uniform pressure value across inlet surface, i got it as various colour bands depicting a range of values over the surface
This should not be the case where uniform velocity is specified. {there is no turbulence at inlet.}
Please clarify regards srivatsan
Old   March 11, 2005, 06:03
Default Re: Pressure plot problem
carno
Firstly do not average the cell data (cave command). While plotting put the cell average option off. Plot and see. It may be averaging the pressure with shells at inlet, which do not have any pressure data.
Old   March 11, 2005, 22:15
vatsa
hi carno thanks for the reply
i didnt do any averaging option at all.. i just plotted the pressure values..
i did one more std nozzle problem (with similar BCs) where i got uniform pressure at inlet.
please clarify vatsa
how to plot the average pressure over each period? Tsui Phoenics 1 June 5, 2008 09:16
Plot pressure coefficient ryan_m OpenFOAM Running, Solving & CFD 0 May 19, 2008 21:20
Hole in pressure plot DAK565656 CFX 0 October 4, 2005 05:01
plot: pressure-time kein CFX 1 May 19, 2005 14:48
PLOT TIME vs PRESSURE Parshant Dhand FLUENT 0 January 17, 2003 15:31
