Home > Forums > CD-adapco
*** WARNING #065 *** OUT OF BOUNDS VALUE???
Old   March 12, 2005, 16:10
Default *** WARNING #065 *** OUT OF BOUNDS VALUE???
Ted Crilly
hello again,
has anyone come across this error when running star
*** WARNING #065 *** OUT OF BOUNDS VALUE -2.9807E+05 FOR SCALAR VARIABLE ENTH AT CELL 226381. CORRECTIVE ACTION TAKEN
it stops reporting this warning after 100 cells have the out of bounds value
this error is reported in my .info file, there is a massive amount of heat input into my domain, and the results are useless.
Does anyone have any pointers or things i need to check to resolve this warning 065.
my model is a large domain, with many inlet and fixed outlet, medium velocity (5-12m/s) 1.8m fluid cells, hvac scenario in a room
i'm using k/e high re number, wall functions, simple algorithm, steady state run,
i would appreciate if some users could point me in the right direction for things i should be checking in order to get my simulation running
thanks in advance
-ted
Old   March 12, 2005, 16:18
Default Re: *** WARNING #065 *** OUT OF BOUNDS VALUE???
Ted Crilly
sorry forgot to mention,
Initial run my differencing scheme is set to u,v,w Mars 0.7 relaxation turb k/e diss UD 0.7 relaxation temp mars 0.95 relaxation viscosity 0.95 relaxation
density is constant
temperature calculation on
etc
any advices?
tia
-ted
Old   March 14, 2005, 11:18
Somnath
try to reduce the pressure correction value, by the way whats the value of blending factor for MARS scheme?
Old   March 14, 2005, 13:02
Ted Crilly
hi,
the blending factor for Mars is default setup of 0.5
i changed the discretisation scheme to Upwind Diff and changed density to F(t) and it now runs fine without giving the warning 065.
Maybe i should not use Mars for the initial run as this is a 2nd order scheme?
would i be correct here?
thanks somnath
Old   March 14, 2005, 13:28
Somnath
ya thts rite.
Thread Tools
Trackbacks are On
WARNING #009 Gavin CD-adapco 1 June 28, 2010 04:17
Bounds error detected Felix CFX 2 July 30, 2007 13:35
temperature out of bounds thomas CD-adapco 0 March 20, 2007 07:01
Solver: Fatal Bounds error detected hagupta CFX 5 March 24, 2006 11:17
F-90::Regarding Chk bounds Arnie Main CFD Forum 4 June 10, 2005 10:40
