March 14, 2005, 03:30 |
Zero-Grad Pressure
Hi all,
I just have a single simple question, which I couldnt find the answer in the user guide. in the pressure BC option, what does it mean by 'zero-grad' for the turbulence switch? when are we supposed to use it as oppose to k/Epsilon? Thanks shazlan |
March 14, 2005, 10:16 |
Re: Zero-Grad Pressure
when u dont know the turbulence intensity or k/e value at any boundary (prefarably outflow) at that position u can give zero-grad so that those value is calculated from er interior solution domain or computational domain.
March 15, 2005, 03:06 |
So, if star can calculate those values for us, whats the point of inputting the parameters to begin with?
anyway, thanks somnath for your reply |
March 15, 2005, 03:48 |
Usually you use zero-grad option it you have "outlet" pressure boundary and specified turbulence parameters if you use "inlet" pressure boundary
Grad evaluation | cfdmarkus | OpenFOAM Bugs | 2 | July 16, 2009 18:54 |
Generalized Neumann BC q f nc grad f%3dg | maddhi | OpenFOAM Running, Solving & CFD | 4 | July 7, 2009 11:27 |
Admission to grad school | Mohit | Main CFD Forum | 0 | October 13, 2008 02:28 |
Best Grad School | ramboy | Main CFD Forum | 4 | October 6, 2008 14:35 |
Grad and lift coefficient | jano | FLUENT | 1 | June 15, 2000 18:54 |
