Home > Forums > CD-adapco
baffle boundary
Old   March 14, 2005, 06:49
Default baffle boundary
sankar
Hi
I am simulating heattransfer between two fluids seperated by baffle. I am giving counducting baffle boundary condition with resistance. I am not getting the proper temperature distribution. Should I re ally go for conjugate heat transfer or the baffle will suffice.
sankar
Old   March 15, 2005, 06:48
Default Re: baffle boundary
Jirka
Conductive baffle boundary condition is suffice for this purpose. Because I do not know your geometry and problem setting I can not advice you the correct setting.
Old   March 16, 2005, 00:08
sankar
I am trying to simulate heatransfer between refrigerant and air in a condenser. I have modelled refrigerat, air and seperated by baffle cells for the tube portion and fins.turbulent flow with ke is assumed. inlet conditions of refrigerant 68C and 14.8 bar
air 40C 1 atm
after analysis temperature for a length of 300 mm is reduce to 20c how this is possible ie refrigerant is cooled below air temperature.
Old   March 16, 2005, 04:54
Jirka
In my opinion, this is not caused by baffle cells. Problem is probably in boundary setting. 20C is Star CD standard setting (e.g. inlet temperature for pressure boundary). If you forget to change it, interesting things can happened. On the other hand some differential schemes make me problems during temperature calculations (but in these cases the temperature is increasing more and more over the boundary values). PS. Have you got some warnings in your *.info file?
Thread Tools
Trackbacks are On
Boundary baffle error 258 Nalleli CD-adapco 2 November 19, 2006 14:14
what different between wall and baffle tipakorn CD-adapco 5 July 25, 2006 03:50
Boundary conditon of a baffle in the MRF region bono FLUENT 1 February 26, 2006 05:07
HELP: baffle generation sunlight CD-adapco 3 July 29, 2005 03:07
baffle in use guang ai CD-adapco 3 November 10, 2003 05:51
