Home > Forums > CD-adapco
Nothing Happens after this: Neither runs nor crash
Old   March 14, 2005, 11:16
Default Nothing Happens after this: Neither runs nor crash
Arnab
when I try to run a simulation either sequentially or in batch mode, my simulation doesnt do after this step. Neither it runs nor it crashes. Can someone tell me the problem?
PBSPro 5.4.0.40152 resource manger detected /N/gpfs/arnab/combustor_rig/trial01/batch.sh: Copyright (C) Veridian Systems Inc. (http://www.pbspro.com/)
*** Only OpenPBS features are supported in compatibility mode ***: No such file or directory
PNP: Initialized [2005-03-14-10:06:04] Automatic Sequential Automatic Parallel analyzer.
PNP: Allocated "ic73-f10,1" resource (1 process).
PNP: Overload STAR master processor with external moving mesh code.
PNP: Assigned "ic73-f10,1" to STAR solver (1 process).
PNP: Assigned "ic73-f10,1" to external moving mesh code (1 process).
PNP: Loading STAR solver dynamic shared object plug-ins.
PNP: Copyright Run Time Portions of this program include material copyrighted (C) by Absoft Corporation 1988-2004
PNP: Analyzing Moving mesh events.
PNP: Starting TRACKER task on "ic73-f10" for monitoring host and process failures.
PNP: Registering STARNET plugin for interaction with "PBSPro 5.4.0.40152" resource manager.
PNP: Spawning STAR process on single node.
STAR 3.20.000 [Circle_002]: linux_2.4-absoft_8.2a-glibc_2.2.2-dso
RUNNING, CASENAME: nalim_a [1]: Dynamic Memory Allocated = 26 MB
*** Using FLEXlm licensing ***
Checking license file:
Checking license file: /N/license.dat
Checking license file: /N/hpc/cd-adaptco/license.dat
Checking license file: /N/hpc/cd-adaptco/star-3.20/license/license.dat
1 copies of starsuite checked out from all other features can only be checked out from same server
Feature starsuite expires in 107 days
*** TOLERANCE CONSTANT SITOL1 (area tol) FOR MATCHING ASI SET TO 0.100000
*** GEOMETRICAL CALCULATIONS STARTED
*** GEOMETRICAL CALCULATIONS COMPLETED
*** END OF EVENT FILE REACHED: NO MORE SPECIAL MESH OPERATIONS, EXCEPT FOR "CHANGE GRID" ***
Old   March 18, 2005, 08:25
Default Re: Nothing Happens after this: Neither runs nor c
John Luo
You have mesh movement by PROSTAR. It seems that when STAR calls PROSTAR to change vertex coordinates, PROSTAR either did not fire up or has error.
Old   March 21, 2005, 21:12
xhliu1
It seems no problem before the calculation solution be printed on screen. you can check,what have you change to the set of analsys solution control.
Thread Tools
Trackbacks are On
ParaView crash srinath OpenFOAM Paraview & paraFoam 2 June 1, 2008 19:03
UDF and AMG solver crash Josef FLUENT 2 August 25, 2005 08:07
crash - help message short Phoenics 1 October 30, 2002 13:16
Unusual Crash leon Phoenics 1 December 6, 2001 06:12
track cause of crash Matt Phoenics 2 October 5, 2001 09:16
