Home > Forums > CD-adapco
negative density
Old   March 15, 2005, 07:29
Default negative density
novice
Hi All,
My run is coming out by giving -ve density error. The fluid is air with compressible setting on. In the geometry there is 0.9 mm gap through which air is flowing and pressure drop is around 5 bar. Is this the reason for -ve density error. My mesh is tetra and I have kept 3 cells in the 0.9 mm gap. I use MARS scheme.
Kindly guide.
Thanks
Old   March 15, 2005, 09:27
Default Re: negative density
Ted Crilly
you might try using UD scheme when starting from scratch and then move onto MARS discretisation scheme, it may help
-ted
Thread Tools
Trackbacks are On
Negative density Ricky CD-adapco 6 June 23, 2004 09:48
negative density Jane CD-adapco 4 March 9, 2004 21:01
Negative density Miriam CD-adapco 0 May 10, 2002 04:21
Negative Density Sangwon Kim CD-adapco 20 May 8, 2001 08:49
NEGATIVE DENSITY M. R. JAHANNAMA Main CFD Forum 8 September 29, 1999 23:59
