Help: Moving Mesh with SUBROUTINE
I use the following codes in prostar:
time trans | mvgrid on | geom,XXX | prob,XXX then in terminal, pmovlink Are you running a local Prostar version? Please enter y or n [n] Please enter the required Prostar driver: Available drivers are: x xm glm [x] Linking pmov executable... FORTRAN 77 Compiler 7.5, Copyright (c) 1987-2001, Absoft Corp. ENTER CASE NAME GEOMETRY FILE TITLE *** ERROR *** MAX PROSTAR CELL NUMBER EXCEEDS 1 RELINK pmov AFTER UPDATING THE PARAMETER FILE =============================================== HOW TO make it correct? thanks |
Re: Help: Moving Mesh with SUBROUTINE
You have to do the pmovlink only if you work with events or do the mesh movement with prostar. So how does you move the mesh? It seems that you have no events defined.
It might help you to run the mixer tutorial at first. |
I move the mesh only with NEWXYZ.f. thanks a lot.
Then, you don't need to run pmovlink at all.
that is to say: I use the "mvgrid on" only, then "starlink". that's ok?
