ProSurf
Old   March 23, 2005, 03:28
Default ProSurf
JBS
How can I read an input file in ProSurf or run ProSurf in batch mode ?
Old   March 23, 2005, 03:51
Default Re: ProSurf
Stephane bone
You can read *.igs, *.iges, *.vda files or *.ezs (prosurf restart file which is better). If you try to open *.igs, *.iges or *.vda, you will have a lot of problems to solve on your geometry. The best way is to use star-design to create your geometry and to export it in prosurf (*.ezs). Then, it will be very easy to generate your grid.
To run Prosurf in batch mode, run prosurf. When you see batch, mesa, gl, write batch.
Good luck.
Stephane
Old   March 23, 2005, 03:58
Default Re: ProSurf
JBS
That was easy. I must have seen it a hundred times - at least it appeard on my screen that often....
Thank you !
Prosurf to Proam problems, help please William Wallace Siemens 11 February 3, 2006 17:00
iges-prosurf-proam-prostar-star elvis Siemens 6 October 17, 2005 04:35
Prosurf in batch mode Dhruv Siemens 1 September 19, 2005 18:02
