*** WARNING #060 *** DENSITY OUT OF BOUND DUE T
Old   March 25, 2005, 16:19
Default *** WARNING #060 *** DENSITY OUT OF BOUND DUE T
varun
*** WARNING #060 *** DENSITY OUT OF BOUND DUE TO PRESSURE CORRECTION AT CELL 1295 DENSITY= 1.2757E-03 LIMITER APPLIED.
i am working on the intake and compression strokes of an i.c.engine.
I am getting this warnings in the .info file and the solution stops saying that the solution is unstable,solution diverges.This iam getting at the very first time step.when the valve starts opening.
what can be done to avoid this warning and to run the simulation.plz help
Create an upper bound daniel_mills OpenFOAM Running, Solving & CFD 0 October 20, 2006 18:34
Density out of bound Prashant Khare Siemens 3 August 1, 2004 22:35
Bound node loop. Jack Keays FLUENT 5 July 9, 2000 13:57
Low Re k-e model bound. conds Abhijit Tilak Main CFD Forum 1 October 7, 1999 05:31
Compressible N-S bound. condn. Kuttoosan Main CFD Forum 1 July 6, 1999 12:46
