Deferent Material
Old   April 1, 2005, 12:20
Default Deferent Material
kfoil
I am working with V3.22 on SuSe 9.1 linux. I do a mesh(Micro-channel sink) in Prostar but I want to define a deferent material (solid and fluid). I have problem between the fluid and solid mesh.What can I do to solve this problem?
Could someone give me a hint?
Old   April 4, 2005, 03:40
Default Re: Deferent Material
Volker
Can you be a bit more specific?
Old   April 6, 2005, 15:58
kfoil
I do a mesh(Micro-channel sink) in Prostar but I want to define a deferent material (solid and fluid). I have problem between the fluid and solid mesh. What kind of Boundary I have to use?
Old   April 7, 2005, 11:02
Volker
You have to use a conducting wall boundary between the solid and the fluid. don't forget to switch on the conjugate heat transfer.
Old   April 18, 2005, 11:12
jing
if you use conjugate heat transfer technique, you do't need to define any internal boundary condition between solid and fluid. The program will caulculate the heat tranfer between solid and fluid automatically.
New Material M.E. FLUENT 6 June 11, 2007 10:06
mixture type material as a phase material Pablo FLUENT 1 January 25, 2007 10:54
Material in DPM yooceframandi FLUENT 8 March 10, 2006 08:19
a new material Neser CFX 0 February 17, 2005 11:47
Add New Material davis FLUENT 1 September 4, 2003 06:51
