Home > Forums > CD-adapco
TclScript
Old   April 4, 2005, 18:21
Default TclScript
TudorMiron
Hi, I'm having problems with StarCD 3.2 For example I'm trying to run 1st tutorial from es-aero: I try to import CAD geometry and imideatly get Error in TclScript which says "Error. error copying param.prp. Object is too big for operation" in fact anything I do it gives same error "object too big for operation" I try ProAmm same thing - objects change (it could be param.prp or writing batch file or anything!) Everything "is too big for operation" Damn! how small do they want it tobe!!! Any way I would appriciate any help or suggestion.
Thanks Ted
Old   April 5, 2005, 17:32
Default Re: TclScript
steve
Do you have write permission in the directory that you are working in? What about the files that are already there - can they be overwritten?
Old   April 5, 2005, 20:12
TudorMiron
It's simply a directory that I made to do StarCD tutorials in. I copied aclass.cel, aclass.vrt and aclass.stab files (ez aero tutorial files) from starCD directory in that new directory... After unsuccesful uttempt to work through tutorial I now have echo and param and couple of other files in that dir.
BTW, I'm using XP.
Thank you Ted
Old   April 12, 2005, 20:48
Kevin
Maybe try going to the star guide and open the section import CAD, choose the one that allows the option cel and vrt. Also I would try deleting the param.prp file and prosize again.
Old   April 26, 2005, 23:54
Wen
I think you may try to change your work directory to install disc. for example "C:\dirname\". The problem may be corrected under windowsXP by this way.
Old   April 27, 2005, 16:08
TudorMiron
Thanks Wen, I'm away from office for till next monday but I will give it a try as soon as I'll get there. Indeed my workdir was NOT on install disc. I'll let you know if it helps.
Thank you Ted
Thread Tools
Trackbacks are On
