Multi cycle analysis
Multi cycle analysis of Engine simulation is done to correctly predict the flow field structure for the engines where the Inlet valve opens before TDC and exhaust valve closes after TDC.
If we want to run the analysis( of 4 stroke Diesel engine ) for multi cycles in starCD other than single cycle what procedures are to be adopted? Thank you in advance for replying. James |
