Fortran Compiler in Star-CD
Old   April 14, 2005, 07:31
Default Fortran Compiler in Star-CD
Anne
Hi, guys,
Except for the Absoft Fortran Compiler, is there any other Fortran compiler that can be used to build the user subroutine in Star-CD? I have Compaq Fortran.
If so, how to set the enviroment variables?
Old   April 14, 2005, 08:58
Default Re: Fortran Compiler in Star-CD
Pauli
Compiler requirements are platform specific. There is a table in the installation notes.
If you do not have access to the installation notes, please be a little specific.
My guess is that you are on 32bit Linux. If so, the answer is no, only Absoft is supported.
Old   April 14, 2005, 12:47
Anne
Thanks first.
I have read the installation note carefully. It is said before Star-CD installation, Absoft ProFortran should be installed. I have no this complier. I am wondering if there are ny other alternatives.
Old   April 14, 2005, 14:01
Pauli
This question has been covered before on this site. You can check the archives.
I am pretty certain the answer is that if the installation notes sais you must use Absoft then you can not substitute another compiler.
Old   April 14, 2005, 16:18
Anne
I see, thanks a lot
Old   April 21, 2005, 02:07
sankar
I am using HPUX11 ant prostar v3.24 what fortran compiler I should use
sankar
Old   April 21, 2005, 13:52
steve
If you are using HP-UX, you have to use HP's fortran compiler. You only need a fortran compiler if you want to write user subroutines for STAR. If not, you don't need one at all.
Fortran Compiler and example Young CFX 1 March 22, 2011 22:26
Fortran Compiler in AIX O.S Rajan CFX 1 July 5, 2005 02:58
Which Fortran compiler ? Harendra CFX 5 February 1, 2005 04:07
fortran compiler sankar Siemens 3 January 29, 2005 13:12
Fortran compiler Arnab Siemens 5 September 14, 2004 03:59
