zero flux boundary for diffusion scalar
Old   April 15, 2005, 05:33
Default zero flux boundary for diffusion scalar
cmv
Hi
Do you know how to set a zero flux boundary for an scalar that is only solved by diffusion. I have tried to use walls and baffles defining a zero flux boundary for this scalar, but it does not seem to stop the scalar from flowing through it. This is a special case, because I have defined other 'normal' scalars (convection & diffusion) that should be able to cross this boundary, but there is one scalar solved only by diffusion that should not cross this point.
I would appreciate any suggestions, Many thanks, CM
Old   April 15, 2005, 05:42
Default Re: zero flux boundary for diffusion scalar
cmv
Hi
It is me again, sorry I forgot to add something, in case you would like to define a zero flux boundary subroutine, how would you code it?
Kind regards, CM
diffusion coefficient in scalar equaton mike Siemens 0 August 30, 2006 11:42
negative values for diffusion scalar cmv Siemens 0 April 18, 2005 06:21
scalar flux boundary condition Murali Siemens 4 May 23, 2003 11:50
scalar advection-diffusion equation Darcy CFX 1 March 12, 2001 09:49
Diffusion Coef. of a Scalar C.H. Huang Main CFD Forum 2 August 18, 1999 03:48
